Блок 036
- WhiteTiger
http://www.mitsubishifuse.com/support.taf?p=7&n=1
TSB-11-54-007
Instructions
Prep:
Format the USB to FAT32
Put the update.package file in the root of the USB
Updating:
Turn the car to ON (don't really need to start it up)
DO NOT PRESS BRAKES
Wait for everything to be loaded on Nav.
Plug the USB in with the update.package file in the USB drive
Press and hold set + navi at the same time for about 3-4 seconds
Go to Hands Free Module
Press S/W Update
I forgot when, but at some point it will ask you for a password/code, just input 1234 (in that order).
Once the update is done, it will reboot and it'll say update successful and you should have version 9.0.0. Then simply press back until you get back exit that especial menu.
Instructions for non-nav system WITH USB port:
DO NOT PRESS BRAKES
Turn audio system "OFF"
Press the following in order: CH1 preset Button, |<< (seek down) button, >>| (seek up) button, and then CH4 preset button.
"HFM DIAG" should be displayed on the system, if not repeat previous steps.
turn the volume to 0
press the "CH4" preset again to toggle through the diagnostic functions
then look for any PN lower than 8785A035 or S/W lower than 0900000
Once you see "HFM OK" displayed, press CH3 preset button to toggle back until "HFM DIAG"
Once you see "HFM DIAG" again press "PAGE" button to enter update mode.
To enter the update security code, press CH1, CH2, Ch3, Ch4 in that order
and the update should start updating.
once that's done press "PAGE" button to return to "HFM DIAG"
turn off the ignition and remove the USB flash drive
test to see if it worked.
TSB-11-54-007
Instructions
Prep:
Updating:
DO NOT PRESS BRAKES
Press S/W Update
DO NOT PRESS BRAKES
Моя мурлыка на DRIVE2.RU - http://www.drive2.ru/cars/mitsubishi/la ... hitetiger/
- WhiteTiger
Можно попросить маэстро Дмитрия, может он чего придумает.
- WhiteTiger
Смысл скомуниздить прошивку 046 и залить в 026. Блоки абсолютно одинаковы, теоретически можно в 025 прошивку от 046 засунуть.anton1978 писал(а):Taк смысл? В блоках 035 нет русского языка, он не для Европы сделан.
- WhiteTiger
Дык поделитесь прошивкой
- WhiteTiger
Какой настойчивыйanton1978 писал(а):так 025 и 035 без русского.vazout писал(а):так есть 026 и 036 блок! с русским.
