Полный список функций ETACS
AlexandrSh
#91 Непрочитанное сообщение AlexandrSh » Вт окт 19, 2010 11:19 pm
Обыдно да
Lancer X 1,8 Intense
kevin
#92 Непрочитанное сообщение kevin » Вс ноя 13, 2011 3:44 pm
Список кодинга 644 етакса (12 модельный год)
Жирным выделил особенно интересные изменения.
Vehicle line
Model year
SST oil cooling fan
Destination
Transmission
Engine type
Engine power
Handle side
Chassis Type for A S C
OSS
Final drive
Transfer
IG off delay control
Deadlock operaion customize
After wipe customize
Tire circumference
Fuel tank
DRL type
Smart entry system
TPMS
Keyless entry
Airbag auto hazard
Immobilizer
Corner sensor
Head lamp auto leveling device
Oil level warning
Water separate warning
Speed meter scale
Idle neutral control
Security alarm sensor
T/M oil cooler
Remote Light ON
Side air bag
ACC Power auto cut
Number of speaker
Seat material
Auto lamp control
Front differential
Rear differential
Power window type
Sun roof type
WCM
OCM
ORC
A/C
AUDIO
AND
Siren answer
Security alarm siren
CAMERA
Corner sensor ECU
Electric Slide door (Left)
Electric Slide door (Right)
ETG
ESS ECU
HFM
Inteligent/Comfort washer custom
H/L leveling system type
Rear wiper mode
KOS door entry type (Sensor & Switch)
Rear wiper by reverse customize
ABS
ASC
Auto fold mirror
SAS
4WD/AWC
TCM
ACTV_STB
Door unlock by IG lock customize
Shift lock
EPS
ACDAYC
Comfort home light customize
Welcome light customize
Indirect lamp
Power window Dr
Power window As
Power window RR
Power window RL
ESS by stop lamp
Sun roof
RLS
IG key illumination
Turn signal bulb
Rear wiper
Fold mirror
Head lamp
KOS func customize by disk
Head lamp washer
Front fog lamp mode
Front fog lamp
Rear fog lamp
Room lamp delay timer/door & H/L
Room lamp by H/L
Gate/Trunk lamp
Head lamp auto cut mode
Head lamp auto cut
Door lock system
Auto door lock/unlock
key remainder unlock
Horn type
Gate/trunk opener mode
Cooling fan
Security alarm mode
Security alarm function
Pre-alarm
Multi mode RKE
Gate/Trunk
Manner Switch
Remote engine starter
Panic Alarm
Right side view camera
Front wiper
Comfort flasher type
Room lamp Center Switch
Wiper washer check bulb
AUDIO/S RADIO type
H/L leveling type
AFS/ACL type
ESS by turn lamp
Compressor type
Temperature type
Rear view camera
Nose view camera
Left side view camera
Average speed
Vehicle language status
Fuel amount
Fuel consumption scale
Seatbelt reminder logic (Except EU)
Coolant temp gauge threshold
Frost warning threshold
Distance to empty
Average fuel consumption
Instant fuel consumption
Time travelled
Distance travelled
Fuel used
Trip autoreset IG OFF
Variable Speed Alarm
Rest reminder
Instant speed
Seat belt reminder type
Seat belt reminder flashing
Seat belt reminder indicator
Reverse alarm
Key reminder
Lighting monitor (available)
GCC speed alarm
Condition buzzer
Rent-a-car mode IG-OFF always
Fuel tank type
Service reminder schedule table
GCC speed alarm indicator
TPMS information
Horn chirp by keyless
Rear S/R Unlock Output
Trailer turn detection
Shift Lever
AFS/ACL/Leveling
Satellite Radio
Auto Stop & Go
Display opening type
GSI system
DRL function
FACU
S-AWC Control display
Diesel particulate filter
Language mode
WSS
Door unlock mode customize
RLS overwipe type
RLS WS type
Launch gear block alarm
Security sensor gain setting
Indirect lamp type
Вот это "Launch gear block alarm" особенно интересно.
HTTPS://BLOCK.MOSCOW
Слесарный и кузовной ремонт
Активация скрытых функций>>
Телефон +7 (499) 3-222-876
#93 Непрочитанное сообщение LancerZ » Пн апр 30, 2012 4:50 pm
kevin писал(а):
Zux писал(а):Да. Длина окружности шины. У нас стоит 7DF, а у аутлендера например 86B. Можно попробовать FFF поставить
не получится. там что-то совсем сложно.
А оно, кстати, работает. Ставишь аутовский размер и спидометр врать сильнее начинает ;).
Прокурор писал(а):
kevin писал(а):Кстати и TPMS надо попробовать активировать. Есть у меня одна задумка.
Женя, попробовать активировать TPMS на машине с европейским WCMом и использовать датчики от Крайслера на 433 МГц?
Если да, то у меня такая же задумка! :)
Никто не воплотил в жизнь?
SVR
Благодарил (а): 3 раза
#94 Непрочитанное сообщение SVR » Ср июл 25, 2018 1:55 pm
kevin писал(а): ...
Instant speed
Эта функция что делает при её активации?
UPD
Также интересно что активируют функции:
Indirect lamp,
lightning monitor
Прокурор
#95 Непрочитанное сообщение Прокурор » Вс окт 07, 2018 8:40 am
Почему же никто? Минимум на трёх лансерах с помощью магистра Ёжика успешно воплощено! :)
