Полный список функций ETACS
Почти любую могу изменить/активировать. Есть очень интересные. Но нужно еще их проверять. Себе много чего изменил.
Для регионов так же доступно.
Vehicle line
Model year
Destination
Transmission
Engine type
Engine power
Handle side
Chassis Type for A S C
Final drive
Transfer
Tire Size
Tire circumference
Fuel tank
DRL type
Smart entry system
TPMS
Keyless entry
Immobilizer
Cruise control
Corner sensor
Head lamp auto leveling device
Oil level warning
Water separate warning
Speed meter scale
Idle neutral control
ENG-CVT unit control
INVECS control
Look-up slip control
Side air bag
Number of speaker
Seat material
Auto lamp control
Front differential
Rear differential
Power window type
Sun roof type
WCM
OCM
ORC
A/C
AUDIO
AND
VES
DISP
NAVI
CAMERA
TUNER
Electric Slide door (Left)
Electric Slide door (Right)
ETG
MSMD
HFM
ABS
ASC
SAS
4WD
TCM
ACTV_STB
Pre-Crush
EPS
ACDAYC
Power window Dr
Power window As
Power window RR
Power window RL
Power window BK
Sun roof
RLS
IG key illumination
Turn signal bulb
Rear wiper
Fold mirror
Head lamp
Head lamp washer
Frontfog lamp mode
Frontfog lamp
Rear fog lamp
Room lamp delay timer/door & H/L
Room lamp by H/L
Gate/Trunk lamp
Head lamp auto cut mode
Head lamp auto cut
Door lock system
Auto door lock/unlock
key remainder unlock
Horn type
Gate/trunk opener mode
Cooling fan
Security alarm mode
Security alarm function
Pre-alarm
Multi mode RKE
Gate/Trunk
Manner Switch
Remote engine starter
Panic Alarm
Front wiper
Comfort flasher type
Room lamp Center Switch
Wiperwasher check bulb
AUDIO/S RADIO type
H/L leveling type
AFS/ACL type
ESS type
Compressor type
Temperature type
Rear view camera
Nose view camera
Side view camera
Average speed
Vehicle language status
Fuel amount
Fuel consumption scale
Speed gauge tolerance
Coolant temp gauge threshold
Frost warning threshold
Distance to empty
Average fuel consumption
Instant fuel consumption
Time travelled
Distance travelled
Fuel used
Trip autoreset IG OFF
Variable Speed Alarm
Rest reminder
Instant speed
Seat belt reminder type
Seat belt reminder flashing
Seat belt reminder indicator
Reverse alarm
Key reminder
Lighting monitor
GCC speed alarm
Condition buzzer
Rent-a-car mode IG-OFF always
Rent-a-car mode IG-OFF door open
Service reminder schedule table
ACD control display
TPMS information
Horn chirp by keyless
Rear S/R Unlock Output
Trailer turn detection
Shift Lever
AFS/ACL
Satellite Radio
Fuel tank type
KOS auto lock customize
DRL function
FACU
S-AWC Control display
Diesel particulate filter
Language mode
wss
RLS overwipe type
RLS WS type
Vehicle line
Model year
Destination
Transmission
Engine type
Engine power
Handle side
Final drive
Transfer
Tire Size
Tire circumference
Fuel tank
DRL type
Smart entry system
TPMS
Keyless entry
Immobilizer
Cruise control
Corner sensor
Oil level warning
Speed meter scale
INVECS control
Side air bag
Number of speaker
Seat material
Auto lamp control
Front differential
Rear differential
Power window type
Sun roof type
WCM
OCM
ORC
A/C
AUDIO
AND
VES
DISP
NAVI
CAMERA
TUNER
ETG
MSMD
HFM
ABS
ASC
SAS
4WD
TCM
ACTV_STB
Pre-Crush
EPS
ACDAYC
Power window Dr
Power window As
Power window RR
Power window RL
Power window BK
Sun roof
RLS
IG key illumination
Turn signal bulb
Rear wiper
Fold mirror
Head lamp
Head lamp washer
Frontfog lamp mode
Frontfog lamp
Rear fog lamp
Room lamp by H/L
Gate/Trunk lamp
Head lamp auto cut
Door lock system
Horn type
Cooling fan
Security alarm mode
Pre-alarm
Multi mode RKE
Gate/Trunk
Manner Switch
Panic Alarm
Front wiper
AUDIO/S RADIO type
H/L leveling type
AFS/ACL type
ESS type
Compressor type
Temperature type
Rear view camera
Nose view camera
Side view camera
Average speed
Fuel amount
Distance to empty
Time travelled
Distance travelled
Fuel used
Rest reminder
Instant speed
Reverse alarm
Key reminder
Lighting monitor
GCC speed alarm
Condition buzzer
ACD control display
TPMS information
Shift Lever
AFS/ACL
Satellite Radio
Fuel tank type
DRL function
FACU
Language mode
wss
RLS overwipe type
RLS WS type
HTTPS://BLOCK.MOSCOW
Слесарный и кузовной ремонт
Активация скрытых функций>>
Телефон +7 (499) 3-222-876
Позволяет отключить автосброс средних показателей
- Hell Rider
К сожалению эта функция пока только как дополнение к американской версии сигнализации.
- Hell Rider
Есть, нужно проверять на работоспособность. Времени достаточно много занимает.
Кстати и TPMS надо попробовать активировать. Есть у меня одна задумка.
Я находил датчики 1-в-1 как америка только на 433
Должно быть так. Не проверял. Не слежу просто.Soundmaster писал(а):Kevin, это реально отключает сброс показаний, после простоя машины больше 4 часов?
Что нашел/проверил:
- режим DRL ближний свет в полнакала!
- омыватели фар работающие независимо от омывателя стекла/двойное омывание/омывание совместно со стеклом
- сигнал на приборке БИП..БИП.. при включении задней передаче
- индикация и звуковой сигнал "выньте ключ из замка" при глушении автомобиля (для тех кто забывает ключ)
- выбор времени постановки на сигнализацию 6/10 секунд с сигналом или нет (в салоне)
Это то что не знал.
все время забываю... И не знаю, включена ли у меня такая опция. Просто мне она не актуальна, у меня на MMCS любой режим под рукой.Soundmaster писал(а):Проверь пожалуйста wink.gif С утра когда машину заведешь, посмотри, сбросился ли расход или нет. smile.gif
Кстати! Вчера был успешно отключен индикатор и пищалка непристегнутого ремня пассажира!
Похоже есть разница в подключении задних фонарей. Разбираюсь
