Случайно сбросил напоминание о ТО
Собственно, дело вот в чем: ковыряясь в настройках БК случайно сбросил показания напоминания о прохождении первого ТО (сейчас пробег 1100), напоминание было, что через 13900 или 12 месяцев. теперь высвечивается инфа о том, что следующее ТО через 20 с чем-то тысяч или 24 месяца. кто-то сталкивался с этим? как можно вернуть в исходное положение?
A.SH.
HOW TO SET BY SPECIAL OPERATION OF SWITCH
By operating the multi information meter switch of the combination meter, the service reminder warning cancellation and the schedule setting can be performed.
HOW TO CANCEL THE SERVICE REMINDER WARNING
caution
Be careful not to execute the service reminder warning cancellation by operating the switch again after erasing the service reminder warning indicator which is currently output, because the next warning period will be cancelled.
If the next warning period is cancelled by mistake, the cancelled warning period can be restored by setting a schedule different from the current one once, and then returning it to the previous schedule.
1.Turn the ignition switch to the "OFF" position.
2.By operating the multi information meter switch, the warning period is displayed on the odometer.
3.Press the multi information meter switch once for 1.2 seconds or longer.
4.The service reminder indicator flashes.
5.While the service reminder indicator flashes, press the multi information meter switch once for less than 1.2 seconds.
6.The service reminder indicator is turned ON, and "CLEAR" is displayed on the odometer display for 3 seconds.
7.After "CLEAR" is displayed for 3 seconds, the warning period to the next time is displayed.
HOW TO SET THE SCHEDULE
5.While the service reminder indicator flashes, press the multi information meter switch for 1.2 seconds or longer and 3 times consecutively.
6.The service reminder indicator is turned ON, and the current schedule is displayed on the odometer display.
7.While the current schedule is displayed, press the multi information meter switch for less than 1.2 seconds and 3 times consecutively.
8.The odometer display is shifted to the schedule selection mode.
9.When the multi information meter switch is pressed for less than 1.2 seconds, the schedule is shifted, and when the switch is pressed for 1.2 seconds or longer, the displayed schedule is set.
note For schedule, "JPN", "NAS", "GCC" and "AUS" can also be selected. However, the using shall be for "EU" only.
10.The schedule set in Step 9 is displayed for 3 seconds, and the warning period to the next time is displayed.
Schedule tableSchedule
Contents of schedule
EU 1 (initial condition)
Elapsed time (month)
Every 12 elapsed month
Driving distance (miles)
Every 9,000 miles of driving distance
Driving distance (km)
Every 15,000 km of driving distance
EU 2
Every 12,000 miles of driving distance
Every 20,000 km of driving distance
Optional INT
The optional schedule can be set. (Only M.U.T.-III can be set.)
OFF Display
Without function. "OFF" is displayed on the odometer/tripmeter.
Function OFF
Without function (Only M.U.T.-III can be set.)
HOW TO INACTIVATE THE SERVICE REMINDER FUNCTION
By setting to "OFF Display" or "Function OFF" when the schedule is set, the service reminder function can be inactivated.
When "OFF Display" is selected
Even if the service reminder screen is displayed by operating the multi information meter switch, "OFF" is displayed.
When "Function OFF" is selected
Even when the check warning period is reached, the service reminder display is not displayed.
Even with the multi information meter switch operation, the service reminder screen is not displayed.
caution
EU 2
Optional INT
OFF Display
Function OFF
2.0 CVT
- Shark
