Эво прошивка зашитая в штатный мозг поедет, правда без мивека, не известно выпускного или обоих. + Мне кажется в стоимость этого чуда влазит эво мозг. эво валы эво мап и шестерня
Компрессор ROTREX
http://www.ebay.com/itm/2011-MITSUBISHI ... 7f&vxp=mtr
11к
http://www.ebay.com/itm/OMNI-POWER-4-BA ... 07&vxp=mtr
3к
http://www.ebay.com/itm/Brian-Crower-St ... 49&vxp=mtr
Это тюнячьи, стоковые будут ~8 - 9к
http://www.ebay.com/itm/Evo-X-Piper-Rac ... 1c2fde6f0a
Вот тут со всей фигней. 18к
11к
3к
- tryval
По моему то , что надо http://www.ebay.com/itm/08-10-11-12-LAN ... 53fa4e1203 , и дешевле .
ZEDAN
Короче ребята!
Вот такая переПиска................
Dear Alexander,
No problem,
I listed below the answer to your question.
1.If MIVEC can not work with the P-MAP but we have correctly set up the air / fuel ratio, whether the engine to work correct with the compressor Rotrex?
2.The program for P-MAP only in Japanese or English too?
3. Just tell me please))) If I install the P-MAP, compressor and all the mood - my 4B12 engine will work properly?.
I just do it the first time.
1.Only not work MIVEC,other work correcrly.
2.We have both.
3. Yes,you can do it.(i will support it)
On account request to include everything you need for installation.
1.P-MAP with a set of
2.Calibrator
3.Ignition adapter type B (if I understand correctly.)
It is possible that something else?
A: I'm sorry, calibrator no need.
I attach the revise incoice.
Please confirm it.
If you have any question,please let me know.
Thank you so much.
Best regards,
haykawa
________________________
Dear Mr. Haykova.
Yes, I confirm the order.
'll Pay on Monday, SWIFT will be in 2-3 days.
And the last question that torments me.
MIVETS will not work at all or will work as before?
(before installation of the compressor and the P-MAP)
Will be saved the Variable Valve Timing?
Or the valve will be opened at one corner?
What is bad for the engine?
This is solved if you install EVO camshafts, camshaft gear and EVO ECU?
Thank you very much.
Aleksandr.
____________________________
Dear Alexander,
This P-MAP is Piggy-Back computer, connecting to genuine ECU.
Therefore, you do not wire to MIVEC.
It is no problem for using genuine one.
MIVEC works normally because it cannot control by P-MAP.
Thank you .
Best regards,
hayakawa
Корче MIVEC как работал, так и будет работать.
Как открывал так и будет открывать клапана.
P-MAP нужен для сопастовления воздух/топливо и давление , ну это грубо конечно.
Вообщем я оплатил , жду отправки. Цена вопроса с доставкой
24500 руб.
Dear Alexander,
No problem,
2.We have both.
2.Calibrator
Please confirm it.
Thank you so much.
Best regards,
haykawa
Dear Mr. Haykova.
Aleksandr.
Dear Alexander,
Thank you .
Best regards,
hayakawa
24500 руб.
Lancer X -2007, 2.4L, 5MT, 4WD и много других букв и цифр.
ZEDAN
По поводу форсунок EVO......
С красной пимпкой -EVO.
Вот тут круз на подобной херне настраивали:
http://www.drive2.ru/cars/chevrolet/cru ... 152335703/
Бред про кислородный датчик не читай, он работает только в ClosedLoop, читай только на частичных нагрузках, и ели бы fueltrim ушел за 10% то выскочила ошибка...
